WTB
driver side door . one piece window regulator
CAR:
VICTORIA
POSTCODE:
CONTACT: Gav 0412407300
hehhe
what for beetle 6 volt
kombi
12 volt ?
12 VOLT BEETLES ONLY HAD THEM IN 1968... 1969
and are hard to find... $$$
You can reuse Your old one...
drill out the rivets and turn the gear over...
re-rivet or use screws....
only half of the gear is used at a time....
i need it to fit a beetle
wahat year beetle they vary
its for a 1969 bug
Its the middle lifting bracket has broken away from the coil spring thanks
