WANTED - Ignition Lock
funbug - May 18th, 2010 at 08:28 PM
I am looking for the ignition lock on a 75 Super. The part number is 113905851A. Would prefer one without an ignition switch and key. Thanks Denzil.
0429878589
Joel - May 18th, 2010 at 08:49 PM
is it just the plastic casing and alloy housing your after?
as in a full column like this but with the igntion switch, key barrel and stalk switches removed?
PM me i got one for ya
DylanTheDubber - May 18th, 2010 at 08:59 PM
Joel , If you wanna get rid of one of them metal casting ones ill take one i need it for parts for my 72 at the moment i only got a indicator stalk
(erlyer style)
From Dylan
funbug - May 18th, 2010 at 10:31 PM
Originally
posted by Joel
Joel. Thanks! I am after the alloy housing. I have an ignition switch which is keyed the same as the door locks.
68AutoBug - May 19th, 2010 at 12:00 AM
Originally
posted by funbug
Thanks Denzil.
0429878589
Why don't You want the switch & key??
You have quite a selection there Joel..
Joel - May 19th, 2010 at 05:27 PM
Originally
posted by funbug
posted by Joel
no dramas i'll get the barrel and switches pulled from one and PM you for details
funbug - May 19th, 2010 at 08:02 PM
Originally
posted by 68AutoBug
posted by funbug
Thanks Denzil.
0429878589
, I want the ignition and doors keyed the same so that I only have one key for the car except for the fuel tank key.
