I'm after a sun visor that is suitable for my 56 oval, also after the bit that makes the horn works, think its called a horn bush???
PM me, I'm based in Melbourne so ideally would like to pick up something up locally, postcode 3054.
hi, the sun visor and horn brush kit u can find on wolfsburgwest, a company in the U.S.
look here:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113857552
and here:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111998011
cheers,
blair
these parts are generic up to 1960 incl big rear window bugs
so if u see later non oval check emm out
i still say 58 is ure plastic also 59 may hve chnged in 60 sometime
check it out I had several amongst many 58, incl
the visors of both are plastic but are different shapes plus the mounts and mirrors are competely different. an oval mirror mounts with the 3 screws in a triangluar pattern point down, the big window mirrors mount with again 3 screws but with the triangle point up.
