Guages
ozjeff - August 26th, 2010 at 06:57 PM
VDO Royal Cockpit (white with chrome surround) oil temperature and oil pressure gauges with senders
Oil temp sender is the sender which goes in your sump and the oil pressure sender is a dual terminal M10x1 80psi
$250 for the set
Brand new never opened
ozjeff - August 26th, 2010 at 07:01 PM
Contact Jeff via pm or 0417577107
Items located in wollongong, will send registered post
ozjeff - August 31st, 2010 at 06:49 PM
bump
