Seagull Neil
Perth WA
0407074141
Post code 6105 Location Kewdale
5MT 4.444 ratio
V4 sti DCCD center diff , close ratio STI gears,
$1800.00
5MT 3.9 ( duel range liberty )
$450.00
Note : You can replace the crown wheel and pion with Todds gear set and very easly leave out the duel range section of the box
so these are easily adaptable to a superbug, or is there quite a bit of work.
where and what would be required to fit for this transition.
gear boxes added
2 boxes sold
v4 box reduced
4.1 ratio JDM 5 MT
$800.00
