I have several good race engines here that I will be slowly building them to sell off as I am up-grading to larger capacity engines . This one is has
the following components :
* 4 piece Autocraft Aluminium case , 94mm bore with std type 4 mains , cut for flanged crank
* Scat forged 86mm flanged crank , std type 4 mains and std porsche rod jnl
* Carrillo 5.7 H beam rods with new bolts
* Autocraft 9526 steel nose cam with Magnum straight cut gears { or cam of your choice }
* Wiseco 94mm Forged pistons , HPC ceramic tops and teflon skirts , with new total seal rings and teflon buttons
* Century long cylinders to be cut to length
* Autocraft 910 heads , 48.5 x 37.5 titamium valves , K 800 springs , HPC ceramic chambers and ex. ports , 37cc , flow 237cfm @ 25" @ 600 lift
* Autocraft 1.25 pro-series rockers
* Autocraft dual tapered pushrods and spring loaded tubes
* Autocraft 3 stage dry sump pump
* Scat flanged flywheel with 180mm dual disc set-up
* Match ported intake manifolds with 51mm IDA's
This engine can be sold un-assembled or I will assemble to your requirements . All parts have been magnafluxed and passed all good . I also have a
complete turbo system including a freshened Garret T72 turbo , complete 2'' HPC coated exhaust , 2 x turbosmart wastegates , fabricated HPC coated
intake manifold with a chassis shop blow off valve and complete methanol fuel injection system . This engine has produced 245 HP on carbs and 497 HP
with 22psi boost . This is a full race deal only and will require regular maintainance and is located in Wollongong NSW and is priced @ $ 10,500 with
carbs or $ 14,000 with turbo deal , ROD , 02-42729920 .
$10500 with cards?
Bloody good deal that. Better than McDonalds. They only give you plastic toys.
Old Hutcho
Will this fit my '71 super bug with out any major mods?
got any pics
Menangler , please define major mods . This will bolt directly onto your transmission as long as you change the oil to a full synthetic deal . ROD.
