I'm after a few odds and ends to finish my bug. I need two black interior door handles and the pipes that run off the black "t" box to the air
channels on the dash. Also the 3 vents on the dash.
Please excuse my poor explaination of parts but I have no idea of their names.
Oh also an aerial
Can anyone help me with the name to these parts?
think i have the handles...def have chrome ones....do u need the backing piece also? $25posted for the pair compl inner
vent pipes are often brittle by now so use other hosing if u can unless u r a purist
same probl with the vents..brittle esp in Qld!
unique Auto Parts should have most of these bits, only the vents may be doubtful.
New aerials which fit in the factory hole at the correct angle are available from most Super-Cheap Auto, Repco etc. Usually about $20-$25, they also fit early '90s Toyota Hilux.
I'm still after these parts. I'm actually after the black handles that you pull to shut the door, not the ones that open the door. Cheers
u mean the black rubber armrest/pulldoorshut variety
give us the mounting hole distances as I hve Golf and beetle ones...
I'll let you know as soon as I get home cheers
Hi Bushed,
any beetle handle should fit as I don't have any holes in my door trims. If you have black ones that would be good.
Angelique
the vents you can get the outer 2 new but the one in the middle is hard to find as they dont make them atm.
and before dave chirps in vintage most likely will have them.
