FS - newcastle LOWERED front struits - suit 71 beetle
ian.mezz - October 20th, 2010 at 02:35 PM
Suit a 1971 beetle with a 3 bolt ball joint on the bottom. Will lower a standard beetle 80mm and give you approx 150mm ground clearance depending on what wheels & tyres you use
the struits have been fitted to a vw but never been used .
$150pair
Contact Ian 0439 917 215 or pm me
post code 2287
newcastle NSW
IT'S THE YELLOW ONE AND THEY COME AS A PAIR
http://img.photobucket.com/albums/v419/montem/1015101450-00.jpg
ian.mezz - November 8th, 2010 at 06:07 PM
bump :blush:
ian.mezz - November 9th, 2010 at 07:36 AM
http://img.photobucket.com/albums/v419/montem/1015101548-00.jpg
PASHN8 - November 9th, 2010 at 10:56 AM
Will these fit a '74 curved windscreen L-Bug?
Joel - November 9th, 2010 at 11:01 AM
95% of 74s are the later 2 bolt front end not the early 3 bolt like these
DylanTheDubber - November 9th, 2010 at 05:04 PM
Shotty these. Will be going on our 72 super.
From Dylan
beetleboyjeff - November 9th, 2010 at 06:53 PM
Dylan, do you want me to bring them back to Port on Friday or Saturday night for you?
DylanTheDubber - November 9th, 2010 at 07:13 PM
Jeff , yes That would be a big help. although i have to get the money sorted first might not be for couple weeks till you can pick them up though till i get all my money sorted??
From Dylan
beetleboyjeff - November 9th, 2010 at 07:46 PM
OK, let me know. I will be starting to work in Orange some of the time in the next few weeks, so I may not be coming home every weekend - otherwise by the time I got home, I woud pass myself on the way back lol
DylanTheDubber - November 9th, 2010 at 08:21 PM
Ok Jeff Joliet you know. Shit you really are doing it hard with alot of work everywhere when do you think you will be getting back to port jobs ?
From Dylan
beetleboyjeff - November 9th, 2010 at 08:24 PM
Good question. I am just chasing dollars for a while (for once in my life). Only a few years I hope. I miss Port heaps though - will be interesting to see how I last.
DylanTheDubber - November 13th, 2010 at 07:29 AM
Sorry Ian - Been thinking i would need to buy a bump steer kit for these aswell and i dont have the money for either at the moment.
FREE BUMP!!!
From Dylan
jeremyluke - March 29th, 2011 at 05:01 PM
Would these simply bolt on to lower a '71 super ? Or would I need to make other adjustments / buy other parts to prevent rubbing or effect steering ?
Pumba - March 29th, 2011 at 05:07 PM
You might be better ringing Ian,this add was posted on 20/10/2010.
cheers shane.
ian.mezz - March 29th, 2011 at 06:29 PM
It all depends on what wheel mags , stock rims etc.thats the fun of owning a old car , you just bolt them in and then see if tyres etc dont rub on the guard etc
jeremyluke - March 29th, 2011 at 08:02 PM
Stock rims and tyres is what ill be using ... ? Did you have yours on a standard or a super ? reckon it will make a difference ?
ian.mezz - March 30th, 2011 at 01:53 PM
apparently there are 2 types of stock rims ??, mine had the smaller out side dish and the wheels just missed my guards.
1303Steve - March 30th, 2011 at 11:12 PM
Hi Ian
What did you take them out for? Looked like a good way to get some ground clearance for the sump.
Joel - March 31st, 2011 at 08:44 AM
Well 2 different widths and 4 different offsets.
As long as they are the correct 4" et34 for a 71 super you shouldnt have any dramas with 165 tyres.
jeremyluke - March 31st, 2011 at 10:01 AM
Is there anyway i can tell what they are ? (Written on it somewhere ?)
Joel - March 31st, 2011 at 10:43 AM
Yeah it's under the hubcaps stamped on the raised sections in between each wheel nut.
Depending how many coats of silver foam the rims have had in there life it can be abit hard to read.
jeremyluke - March 31st, 2011 at 03:31 PM
I cant see much under the hub caps. I can make out the VW logo on most of them, 3 of them I can see 8/70 7/70 and 7/71 which i assume are the dates, and 2 i can see 4JX15 and another just the '5' but not 4 ET34. This is a 1/71 super
They all have 165 r 15 tyres tho
Joel - March 31st, 2011 at 05:28 PM
Sometimes the stampings are hard to see and a bit faint but most of the time theyre just buried under paint.
You got 3 different date rims there too.
Width, date and offset.
jeremyluke - March 31st, 2011 at 08:31 PM
I'll have to get the buffer wheel out and get sum of that paint off, it usually brings up the stamped VW logo pretty well on other parts I've used it on. Im pretty sure the 7/71 rim I have swapped from my other super which was made 8/71 and it isnt running stock so i used the rim with the best tyre. But there must be a few layers put on there cause I can really only see the heavy indented "T" shape on a few, no where near as clear as yours Joel.
