I am doing a resto on a '56 Oval and need the following parts.
1 x rear tail light glass lens and wire clip to hold it into the housing
1 x oval headlight glass with VW emblem at the top.
LH and RH 1/4 windows, must be in very good condition, no rust or pitting.
LH and RH division bars for 1/4 windows, again must be very good.
If you can help phone 0402 003965 or PM
Dave
Dave, Can you post a pik of the headlight glass you have and I will see if I have a match. Both Hella and Bosch made them, and they also have different numbers along the bottom (or no numbers!)
hi, i have a rear tail light lense, but not the clip for $27 if you want it, the glass is in really good condition but the back metal part is a bit rust, but then again i looked through my stash and all of them where rusty
i got the clip
and qtrs BUT oval ones have longer shaft so stainos prob don't
also some great and some ordinary but workin sema4s!!!
may have lens (shood hve an ellipse in centre of lens about the size of the tailiteglass!
pm if u want
Guys, thanks for all the replies and phone calls, I have been able to locate all the parts I need.
there will probably be more as I go through all the boxes of bits that came with the car.
Dave
