I have a brand new engine I have just finished assembling that would suit any type 1 , type 3 or early Kombi . All components are brand new and are of
the highest quality . This engine has a comp. ratio of 9.34:1 and will have a slightly rough idle due to the camshaft . It has the following
components ;
Magnesium AS 41 universal case , bored and decked
AA performance 69mm forged cro-moly 8 dowelled crank
AA performance 5.4" I beam conrods with ARP bolts
AA performance 94mm piston/barrel kit
Engle W 120 camshaft with billet gear
Scat soild racing lifters
Mahle main bearings
KS rod bearings
Mahle dual thrust cam bearings
New bearing dowells
New crank gear set
New dizzy drive
New flywheel shims
AA performance 12 volt lightened 8 dowell flywheel
AA performance cro-moly gland nut
CB performance Los Panchito CNC ported heads with 40 x 35.5 mm stainless valves
Solid shimmed used VW rocker arms with scat swivel feet adjusters
new cyl deflector tin
Empi cro-moly 8mm head stud kit
In/out 26mm oil pump
New case install kit
New case nut and bolt kit
Billet dipstick
Scat stainless steel valve cover kit
This engine should be good for 130 hp and is suited for a set of Webers or dellorto's . This engine is priced @ $ 5100 and I can include a good set
of 44mm Webbers or 45mm Dellorto's for and extra $ 650 for a complete kit including manifolds , air filters and linkage .This engine is located in
Wollongong NSW and can be shipped Aust. wide via Toll Express , ROD , 02-42729920 .
Iam after one for me type 3 fastback do you have any pictures?
Chris7 , this engine will fit into your type 3 without any modifications . I will try to post some pic's when I get a chance , but it looks like a new engine . I can also swap the type 1 intake manifolds and air cleaners for the type 3 units if you want the carbs , ROD , 02-42729920 .
Looks great! good luck with the sale rod. Was nice to meet you at day of the drags. Nick
Wow Bargain Rod! If I hadn't already gotten mine I would snatch this up so quickly
i am after a good set of twin 44 webbers for my 2180 beetle, n what other bits you got. thanks Gordon
Going to rod's place is like going to VW heaven, rod has everything to build ten beetles at least.
Rod doesnt visit that often here it is easier to call him 02-42729920 .
has it been on an engine dyno? 130hp sounds awesome!
Call him. he will have what you want.
Anyone have an idea roughly of what a 2+ litre engine with carbs would cost? eg 2180,2232 etc
the extra cubes
wont be much different, only a crank shaft.
I am cleaning up my shed and tripped over this engine last week . This is still here and I would like to move it on . Please call me with an offer as I need more space . I can ship this anywhere as is or I can make it a complete turn key deal for approx $ 7000 with a set of 40mm Webbers , new Kennedy clutch , new 1 5/8 merged header , new cooling system , new ignition system , new tinware , int. reg. alternator ect. , ROD , 02-42729920 .
