Brand new 2800cc type 4
RodPenrose - December 15th, 2010 at 07:51 AM
I have a complete 105mm x 80mm type 4 engine here I have not had time to install in my bus . It has a Scat c35 camshaft , lube-a-lobe lifters , 105mm
JE pistons , Scat H beam rods , Fat Performance crank , porsche cooling kit , 48mm IDA carbs , 200mm flywheel , Squareport heads , 48 x 40 stainless
valves ported relocated plugs , and a lot of other good parts . I would like to get $ 9000 for this engine that is located in Wollongong NSW , ROD ,
02-42729920 .
vwsteve - December 15th, 2010 at 08:03 AM
just what i always wanted, if only i had money
HappyDaze - December 15th, 2010 at 09:15 AM
Crikey Rod, that would be the go in 'No.8' Beetle
By the way, - I
won't tell anyone - you left off the post code
The death penalty
still applies, I think.
LUFTMEISTER - December 15th, 2010 at 04:07 PM
crucifixition.....1st offence
The "comfy chair"......2nd offence
2 weeks in woolongong... 3rd offence
4 weeks in woolongong ...4th offence
sweet sweet death (after the gong)......5th offence
matberry - December 15th, 2010 at 11:11 PM
typ268 - January 10th, 2011 at 06:01 PM
Would this go into a 1960 bus?
Could I get it registered with a brake upgrade?
What else would I need to do?
Thanks.
Craig Torrens - January 10th, 2011 at 08:25 PM
Originally
posted by typ268
get NRMA membership
its worth it for all older cars
johny rotten - January 10th, 2011 at 08:30 PM
Originally
posted by Craig Torrens
posted by typ268
get NRMA membership
yep go with NRMA Gold
johny rotten - January 10th, 2011 at 08:31 PM
Originally
posted by typ268
Thanks.
Yeah Get Wayne to do the Blue slip
tell em its a 1700
typ268 - January 11th, 2011 at 07:39 AM
Thanks for the help.
So its a no go then?
hellbugged - January 11th, 2011 at 07:54 AM
Originally
posted by typ268
give Rod a call (the seller of this engine) he will be able to answer your questions and probably have alternatives if this motor doesn't suit.......
