Yeah I know, what are my chances but thought Id throw it out there anyway. Getting up and running my restored HJ ute and am after a Rochester
Quadrajet carby and good 4 barrel manifold to suit. Also Bosch electronic ignition (all for a 253 V8).
If its gathering dust and can find a new home, let me know.
Cheers, Andrew (Sydney)
I've got my ht prem still in the front yard with 253 , edelbrock performer manifold 465 carb, hv oil pump 30 thou over pistons alot of money spent also has turbo 350 with dellow trimatic to turbo adapter , mega shifter it goes on and on about 10grand spent on mechanicals
Sounds nice but I thought about an engine transplant with everything done but this is a 1 owner vehicle in storage for 17 years and thus I would
like to keep all the original matching numbers.i may have a hq 4 barrel manifold somewhere also a cain hi rise one too and "b" cast heads. trimatics 308 stuff
If it's going on a 253 the standard 253/308 intake manifold will be better suited than an edelbrock performer.
B cast heads are what came on the Brock commodores as far as I know, but then again, I don't know much : )
I have a stock intake here too to suit red heads if you're interested.
Klaus, is the cain manifold a tunnel ram (twin carb) or single carb? I'm chasing a tunnel ram to suit red heads.
HT prem sounds like a good thing. Just needs a 5 speed : )
Hi, my son left some carby bits with me from a 253, don't know if these are any good, the pics show most of it,
its a dual but missing the top section, the 253 was / is worked and made 180hp at the flywheel not much but enough. Having only a 465 makes it nice to drive well when it wasnt rusted out.
