Cameron 0439768168
post code 4123 QLD
Hey all i have decided to sell the engine i have been collecting parts for over the last six years the engine will need to be put together.
the list is as follows,
as41 case taped for full flow,Malle 94 pistons,scat 69 counter weight crank, cb 044 heads large valves twin springs and ti retainers,porsche fan set
up powerder coated black with carbon fibe shroud,cb sump,complet redline fuel injection with msd and 40mm tb, drd under decklid turbo header, Garett
t3 turbo and wastgate,oil filter, front mount oil cooler, enough braided an6 fuel line and fittings to fit off, carter lift pump.
the only things you would need is head studs to finish this top of the range engine.
price $6500 obo
spent over the last six years $11000 getting theis parts.
thanks for looking
666bug PM sent
sold pending payment.
thanks Paul
