I'm after the tinware that goes under the cylinders. It attaches to the bottom of the case on one side and the heat exchanger on the other, and
curves up at the front.
After both sides for a 1300SP, anyone got some lying around in decent shape?
I've sorted out the tinware under the cylinders.
Now I'm after the rear tinware for the same engine - the very first piece you come across when you open the deckild that runs the full width.
Angus
Is this any good to you?
Simon
that would be great - I'll give you a ring to arrange a pick-up.
Thanks, Angus
