Whats the KO number?
dont worry, found my own answer...... KO 861
far out
this looks miles better than the one i like to do up
Hmm, that looks interesting. I might just be crazy enough! Is it possible that I might be able to inspect it after work one day this week, about 5:15 or 5:30pm? Or otherwise Saturday?
Lucky you've strapped it down, or the Country budgie would probably fly away.
[Sorry, that was impossible to resist]
I thought that may have been how he has been smuggling it around. lol
Wow, it looks like the wiring is unconventional. Is there a good reason why there is a 240v outlet on the dash?
if i could get it to vic i would buy it now
someone buy it and race it. How cool would this look going down the track.
If anyone knows a cheap method to freight something like this to Qld Geez i'll buy it.
is it perched in the roof section of the shed yet?? lol
Are you serious? I couldn't even sell mine for 100 buks nor swap it for anything.
ok that makes sense. though I paid 150 for a early SA sub-frame. Was a good deal
since it took me a year to fine one and the one I bought at X mas was a fake which I swapped an original Venetian blind for it ![]()
Then I will use my irs frames I have to make a super precise jig and use the brackets of them as there is a problem with using after market brackets
as they are ~45o and cut too much into the horns, but factory brackets are straight with ~45o only on the very tip. This is ideal as it doesn't hack
no where near as much into the horns.
I am going to convert my SA frame with the horns to irs so I can use Craig's kafer bar kit
