Anyone know if any of the Aussie part places carry the solid brass idler arm bushings for Super Beetle? Cant seem to find them here.
IF you cannot find one you could try bearing service, if they do not have the correct size you could get the closest and have it machined to suit, you could use delron or some other plastic material instead of bronze
i got mine from topline... whats wrong with going that way?
$80 for a piece of brass from cip.
thought Id try local first.
Topline ,yep have bought off John before.
hey, i have a similar to the topline setup idler arm with bush & grease nipple already installed, $50 and its yours - and if you have no use for
your current one if its still usable you can donate it
its a brass bush in the steel sleeve, works the same way i guess, just slight alteration on design, unknown origins, let me know
pic of idler
