I have available on the gold coast a set of 4 mercedes mags and tyres suitable for a kombi.
They are 16 x 7.5 ET41 which is same as stock.
currently fitted with bridgestone desert duellers with at least 5mm tread size 215/70/16
with these rims and a 2litre box you will be doing 100km/hr at 3000 rpm
This combination is good for mild offroading and makes the kombi feel rock solid stable at speed on the highway
only drawback is you do need longer studs...apart from that they just bolt on with plenty of clearance front and back
i also have a pair of rear hubs available with 65mm studs fitted to suit these wheel...no front hubs available
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
wheels and tyres $200
Rear hubs $100 for the pair
will separate the wheels and tyres if necessary $120
pm me if interested...cheers Rob
bump
