Have a good Type 3 IRS box for sale, No noises, doesnt pop out of gear, good to go for IRS split conversion or bolt in whatever...... $400 ono Pick up from shop 33564356 Peter
Pity your not in NSW!
Hi Vman, If you already have the IRS rear end of a beetle that you are grafting onto a swinga pan depending on what final drive you are after it
realistically will be no benefit to bolt in the type 3 box if you already have a type 1 IRS box....
Alot of people buy the pivot boxes seperately and weld them into a complete swinga pan as it is easier than cutting the whole pan up.
If you go down that path it is essential you weld them in correctly as that will determine the overall setup of your Camber/Caster and Toe
measurements.
Get this wrong and it will be a disaster!!.
I do sell the Pivot boxes at the shop if your interested...... Hope that helps!!.
