I have one set of brand new, CB performance dropped spindles for sale. These are a forged spindle with a patended design, from a company with a proven
VW performance background for over 30 years. These spindles have a very good reputation for strength and reliability. They are located in Hornsby, and
I am happy to help with freight at the buyers expense, but direct pickup is welcome. Please contact me by PM for further details.
(Note; These are only being sold as I am changing plans from Beetle resto to Type 3 which fits the family)
$185 for the pair
HERE IS THE BLURB FROM THEIR WEBSITE;
CNC Machined from new castings for a perfect fit
Maintains factory steering geometry
Narrower than welded spindles
Use with 50 and 60 series tires
Stronger than welded spindles
'68-later - Use your stock bearings
Chromoly axles
Full 2 1 /2" Drop
Machined for use with larger 1969 & later tie rod ends
Improved ride & handling
Accepts VW rotors or drums
Uses standard length shocks
Models to fit drum or disc brakes
Fits all type 1 ball joint front ends
Uses standard VW bearings and seals
HERE IS THE LINK TO THE PRODUCT
http://www.cbperformance.com/catalog.asp?ProductID=478
Are they for disc brake's.
Thanks.
