WTB - internal door chrome & camber compensator for KG
norbert - June 29th, 2011 at 01:23 PM
Am after internal door chrome for KG. The ones on the door cards and on the top of the door just below windows if anyone has some.
Also after camber compensator.
Calcool - July 1st, 2011 at 08:47 PM
John Sherman at Volksconversions appears to do a good quality camber compensator, you will need to know if yours is a splitcase gearbox or tunnel gearbox as the camber compensator is different.
Same specs as for a Beetle as a Karmann Ghia is a Beelte with different clothes on!
You can get the trims form the Karmann Ghia Company of Australia based in Perth or they are available in the US repro from House of Ghia!
norbert - July 2nd, 2011 at 09:29 AM
Thanks Calcool.
bushed - July 3rd, 2011 at 08:50 PM
u still want the catches Norby
bernie?
