I am currently rebuilding a Semi-Automatic beetle and i need to get the end play worked out. Unfortunately the easiest way i have seen and what most
books say is to use a manual flywheel to measure with. I had a 1200 flywheel rusting away but alas it does not fit a 1600 crank.
This is why i don't really care about the flywheels condition as I'm only using it to measure the endplay.
I am happy to swap the 1200 rusty old flywheel for a 1600 flywheel, or maybe even pay a few bux. (But as i said I'm not actually able to use it
:P)
Let me know.
I'm near Parafield.
Thanks in advance guys.
may have an old one, will check tonight, iam in greenwith. regards craig
DOAH!!!! its 185mm friction plate. 4 dowel. not sure if any good but you are welcome to it. call me 0448866248 10.30am saturday to arrange to pick up if required. Going out 11.30am cheers! Craig
