Hi I am after a flywheel 180mm to suit my 67 vw beetle.
My current flywheel has a groove where the seal has been running and I think it will leak again.
I just need a good flywheel with no groove if possible and with a decent ring gear.
I am in Adelaide.
Smithy
You could go for a seal saver if your flywheel is in good condition. I’ve head people say they are better than new, due to the small increase in
diameter putting extra tension on the seal. Use the very best silicone seal of course.
Perhaps it’s time to go 200mm & 12 volt, who knows?
Good luck mate.
Tony
Yea I have converted to 12volt, running 6 volt starter. I have heard you have to grind out the bell housing on the box to fit the bigger flywheel.
A seal saver hey, will have to look into that, thanks.
Lee is right, (as you would expect from a "Super Moderator")
clearancing
for a 12V flywheel is no biggie. There’ll be info on it all over the internet, as always, some good and some not so good.
SKF call the seal savers "Speedi-Sleeve". Have a look at http://www.skf.com/portal/skf/home/products?maincatalogue=1&lang=en&n...
You can get them at bearing suppliers.
Tony
