Contact: 0401 937 104 or PM
Items:
5x EMPI 8s, 4x130 - fresh powder coat - 4x fitted white stripe tyres. Excellent condition - $500
4x standard Type 3 rims, 4x130 (diff offset than bug) - 4x fitted tyres. Rims in poor condition (not quite round, but no cracks), tyres not roadworthy
- $100
SOLD - 2x V-Force adjustable struts (height and camber adjusters), 3 bolt type for Super/L Bug. Oil shocks. Excellent condition. $500 or $600 with 3
bolt hub assembly if required (this includes spindle, disk, caliper - everything you need to swap out). This is a flat out BARGAIN!
1x L-Bug Dash. Has a crack in centre, but it is covered with carpet. Otherwise good condition. $100
1x L-Bug fuel tank. Something rattles inside. Sender was fine when last used. No leaks or corrosion. $50
2x L-Bug doors. No rust. All things work right. Scrapers are worn and drivers quarter glass lock is damaged (still closes just not tight). $150
PENDING - 1x L-Bug steering wheel, ignition black, steering column assembly. Everything works (key included). $100
1x L-Bug bonnet. Reasonable condition. $50
SOLD - 1x Gearbox - never thrashed and last time was in a car did not have any odd noises or pop out of gear. Very smooth. $300
SOLD - 2x CV shafts and joints. Good condition. $50 for the pair.
1x L-Bug standard sway bar. $50
1x S/L-Bug (not R&P) steering box and assembly. Very good condition, pretty much no play. $200
Glass: 1x rear screen, 1x right and left rear passenger. Seals are good and glass is fine. Has professional tint applied. Suitable for all late model
beetles. $25 a piece.
Guards: Elephant foot rears $50 each. Excellent condition. L-Bug fronts, slight damage $25 each. All four for $100.
SOLD - L-Bug pan: Battery tray gone (literally). Other than that it has no bad rust (some surface corrosion). Passenger side floor has been replaced.
Comes with all rear suspension components including Type 3 torsion bars (if you want to do an IRS conversion). Will not separate. Take it away for
free.
All items are for PICKUP ONLY.
Pictures:
2x V-Force adjustable struts (height and camber adjusters), 3 bolt type for Super/L Bug. Oil shocks. Excellent condition. $500 or $600 with 3 bolt hub
Some one buy these!
Unbelievable value
PM sent
grab the hubs and do the lot!
Eden,
Are the white stripe tyres, genuine white stripes (as in they came that way from the factory) or are they painted on white stripes. What width &
profile are they? loook like Dunlop SP sport???
Brendan
They are painted on white stripes I believe but very well done. Tyres are 195/65 R15, and yes, Dunlop SP Sport. As you can see in the photo, that stripe is a little worn, that is the worst one, all the others are intact.
Do you still have coilovers?
eden as discussed coilovers are spoken for, cheers mate
Struts are pending sale to Scot as mentioned above.
eden sent you a pm dude.
I am new and don't understand PM thing
PM - Private Message
Have a look down the bottom of each post and you will see some boxes
PROFILE SEARCH PM
PM sent in regards to steering wheel/column!
NT Superbug, the struts are now sold. PM replied to Seb.
Eden,
Still got the column,if you need it returned soon..
Let me know when...
Tony
