Decided ill never get around to using this, its an aisin amr500 roots supercharger.
500cc per revolution, can be spun up to 16000rpm apparently.
Fits easily in front of fan shroud. Would make a neat little hot rod 1300 or 36hp etc.
Turns smoothly. very good condition.
$280 ono.
Owen 0413266808
Pick up in bondi or post at buyers expense.
Ill get pics asap or google amr500. they all look the same
Hello,
Do you have the lower pully??
No it's just the blower as removed from whatever jap car it came from. It has a pulley on the blower and the cast bolt on outlet pipe. Should be quite easy to set up like the pic above
t3 use a 3 groove pulley that fits straight in the 1600 or all air motors t3 have it for the power steer and air con
Sold
Cheers!
