WRECKING - 1971 Type 3 Fastback Auto
1970 fasty - January 22nd, 2012 at 01:50 PM
the car is fairly complete. engine was started when i got it and the auto seems to work ok as well. let me know what your looking for and i will see if i can help. Sth Side Brisbane Coopers Plains 4108
0430 204051 John.
dave1342 - January 30th, 2012 at 06:04 PM
Is the rear valance straight on it I'd be interested if it's possible take off.
1970 fasty - February 6th, 2012 at 07:21 AM
Dave, the rear valance isnt perfect and it would need to be cut off as they dont unbolt. i have stripped the car over the weekend - few parts already gone - and only the eng, trans, and front end are still in it. front guards will come off next weekend. shell is in pretty fair nick (make for an easy race car build). buzz me if you need anything. learned heaps during the strip out.
Arpspasm - February 6th, 2012 at 08:38 AM
How much would you like for the rear brake set up? cheers, Dan
Edit actually better check what stud pattern these are as well.
1970 fasty - February 6th, 2012 at 08:21 PM
hi Dan, they are 4 stud and i sent you a pm on the details of the set up. cheers John F.
Fastie - February 6th, 2012 at 09:09 PM
How is the dash? cracks?
Arpspasm - February 6th, 2012 at 11:47 PM
P.m replied too. Daniel :)
1970 fasty - February 7th, 2012 at 07:38 PM
Hi Fasty, yes it is cracked sorry (as per normal)
i am going to try and get it reconditioned locally as the one in my good car is worse. will let you know how i get on.
MrScooter - February 9th, 2012 at 10:33 AM
Pm sent. :tu:
MrScooter - February 9th, 2012 at 09:24 PM
if you got them , im chasing the speedo, and the internal boot light assembly..
NCH-003 - February 11th, 2012 at 05:50 PM
PM sent MrScooter..Re: Speedo
1970 fasty - February 14th, 2012 at 06:20 PM
only the front end left in it now, the shell is alot better than i expected. engine and auto are out. a couple of deliveries happening at dubs on sunday.
68BUS - February 14th, 2012 at 06:56 PM
Do fast backs have the same engine access hatch as the squarebacks? If so could I get that bit cut out to use as an engine hatch in a kombi?
Cheers,
Brad 0418 708 210
urban_myth - February 15th, 2012 at 10:47 AM
how much for the auto,axles and tbar,geoff
1970 fasty - February 15th, 2012 at 06:11 PM
Cheers,
Brad 0418 708 210
1970 fasty - February 15th, 2012 at 06:12 PM
Hey Brad, PM sent this afternoon. regards John F.
1970 fasty - February 15th, 2012 at 06:46 PM
Hi Geoff, PM sent this afternoon. regards John F.
68BUS - February 16th, 2012 at 06:30 AM
Hey mate,
Didn't get the PM. Can you send again.
Brad
1970 fasty - February 16th, 2012 at 07:23 AM
hey Brad, resent PM this morning regards John f.
68BUS - February 16th, 2012 at 03:41 PM
I don't know what going on. Still have not got it. I have got them in the past from other people so know it does works normally.
Can you give me a call on 0418 708 210
or email me on bradarmstrong_99@(Removeforspam)hotmail.com
1970 fasty - February 16th, 2012 at 06:01 PM
Sorry Brad, its worked for everyone else so far, cant figure out what the problem is.
i tried to call and it went to message bank so i left a message for you.
the deck lid should be the same as a sq back however i have a guy interested in the shell and he is coming over next week sometime to inspect.
what dimensions are the section you intend to cut this into? as the dimensions of the lid its self from memory are around 55cm x 80cm.
will be in touch if the shell doesnt go however i dont have any cutting equipment.
catch you soon, maybe at dubs if your in SE QLD. regards John F.
urban_myth - February 16th, 2012 at 06:49 PM
hi brad. i didnt get your pm either.give me a call on 0416 067 932.thanks
1970 fasty - February 16th, 2012 at 09:52 PM
Sorry Geoff, stuffed if i know what im doing wrong all of a sudden. i just click on the pm button, type the message and hit Post PM.
it took me a while to identify if i had a PM as i didnt notice the message under where my log in was on the top right.
i have only just got in (bit late to call) so i'll ring you and Brad tomorrow to discuss your requests.
thanks for your patience guys, John F. (the PM novice)
1970 fasty - February 19th, 2012 at 06:27 PM
thanks for your business Mick and Daniel great to catch up at dubs. stay in touch if there is any thing else you may be chasing.
Short list of some other parts that are now out of the car that may be of interest.
Auto and converter $350
Auto Pedal set and floor covers $45
Shifter assy inc cable and inhibitor switch $65
Accelerator linkage bracket and kickdown switch $35
CV's (Pair) $60
Axles (Pair) $60
if there is anything else your chasing message or ring me 0430 204051
regards John F.
All of the above, bar the accelerator linkage and kick down switch is now SOLD, thanks Geoff
1970 fasty - February 26th, 2012 at 09:15 PM
Some more parts that may be of interest.
Starter motor Suit automatic Part No: 003 911 023A $50 SOLD
Front luggage compartment card (suit demister models) $20
Front Bumper Brackets (pair) $30
Ash tray assy (Colour Shantung) $10
Glove Box Lid (Colour Shantung) $10
Rear Seat Black $30 SOLD
Door cards (Set 4) Black (chewed in places) best for parts $20 SOLD
Demister box, under dash ducts, dash & demister outlets $20
front impact assy & plastic tubes (goes behind front bumper) $15
Rear Window, Rubber and Chrome $40
Side Windows (fixed type), Rubbers and Chrome $40 (pair)
PM me for more photos, regards John.
1970 fasty - February 28th, 2012 at 06:48 PM
few more pics of bits
1970 fasty - March 25th, 2012 at 10:33 PM
forgot to mention the engine (complete inc "flex plate"), streering column - disassembled, ignition switch, indicator switch, heaps of small parts, side and rear windows. contact me to check if i have what you need, can post pics if required.
1970 fasty - August 8th, 2012 at 07:04 PM
Complete Interior - Sold
Shell and Pan - Sold
Stainless Body Mouldings - Sold
