Im after rear suspension and brakes out of a early type 3.
Cheers Shaun
Is it the sub frame your after as well?
Where are you?
Dave
location is handy
Sorry guys im in Newcastle,im after all the bits to do a straight axle conversion on my splitty.
So axles and tubes and the brake hub etc,hopefully wide 5 pattern.
PM Sent
wouldn,t you be better off doing a irs rather then swing axle rear end swap.
Ive got a fully recoed bug box just out of an early model 1300,so thought it would be cheaper to go that way.
But i have all the irs bits out of a bay if someone wants to swap the gearbox for L Bug one.
shaun Ive got a dc type 3 irs box here which is similar ratios if u get the shits with doing the straight axle ,
I've driven both conversions in busses and not a real noticable difference , and my panel is straight axle
daily driven
