Need the following bearings for my stock 1600 rebuild.
Standard cam bearings
Standard big end bearings
Standard main bearings +1mm OD (for line bored case).
Give me a shout if you can help me out.
Mick.
0428428864
mick@vdubber.com
G'day mate,
we have the Mahle cam and rod bearings in stock currently:
Cam bearings:
http://dasrestoparts.com.au/cam-bearing-set-std.html
Rod bearings:
http://dasrestoparts.com.au/rod-bearing-set-std.html
Thought I had the standard crank/1mm oversize case main bearings however I only have them up to standard/0.5mm oversize case sorry:
http://dasrestoparts.com.au/main-bearing-set-50-std.html
Al
What thrust on the mains?
Hi Matt. Thrust is standard, however I took the plunge and ordered them from mofoco at the weekend with some other parts.
Don't think my forum notifications are working, shame as I would have preferred to source them from Aus.
The price of impatience - lol.
Thanks for the replies guys.
Mick.
