Hey guys, Just thought I'd let you know I've almost finished developing my brand new 4" - 4.5" and 5" narrowed beams for busses.
They'll be sporting:
- Specialised steel pipe
- OG needle rollers [ no nolathane bushes!! ]
- custom side plates for shock clearance
- raised centre pin
and a lot of love!
It's taken almost a year of development to produce and source a product that will run original OG bearings and not use nolothane bushes. Everything
on my beams is brand new off the shelf original items.
I'll also be suppling shortened tie rods and other suspension components for a bolt in unit.
I'm looking forward to supplying the Australian VW scene with a top of the line quality narrowed beam.
I look forward to hearing from you with your next project!
Cheers,
Ross | 0412 441 831 | Full website coming soon
http://skinnedknuckles.com.au/
well done and good luck ![]()
Great to hear mate! I look forward to hearing more soon... Both the 72 and 75 will need some treatment...!
If your bus is anything to go buy - these will be rad...!
ah so u are skinned knuckles
I took my white 54 T1 out a few weeks back n after a surf parked it in H street noosa n after coffee came back found ur card on the wscreen
nice one n good luck
will you be able to narrow bay beams as well?
good to hear someone is doing full kits and locally made, i hope everyone supports you we need more of this in Aus congrats and look forward to seeing your work ,all my busses have been lowered so will be keen to use your work ,cheers Paul
Thanks Bizarre and type3disease. Appreciate the support.
Emailed you 'h'
I'm a Noosa boy from way back. This was my daily for
many years up there amongst other dubs: http://a4.sphotos.ak.fbcdn.net/hphotos-ak-prn1/20578_428573785047_4703070_n.jpg
Hi wiseoldub, narrowing an OG bay beam is more work than making a brand new one. I'm using all new OG components (OG needle bearings) so there's no
reason not to get a new beam.
Thanks heaps 66doubledoo!! I'll be sure to keep everyone in the loop on ETA, with build pics along the way, SO close.
A big cheers dragsters for life. Thanks for your support mate!
Thanks for all the enquiries guys! I've received a few emails and thought i'd add this email reply I wrote today that might answer some questions
along the way:
At this stage I don't have an exact price as It's still in production but as soon as I have a cost I'll be sure to let everyone know and post the
details. I'll keep everyone up to speed with an ETA. I'm also working on a website which will have all details and images. I'll make sure to
includes build pics, welds, close-ups etc. I know they're worth there weight in gold.
The units will be bolt in, adjusters standard on every beam. They'll be available for low and highlights yes.
I haven't looked into warrantee at this stage but it is on my list. I welcome any inspection and grantee my only intention is to manufacture a top
quality beam using only the best components. If I was in the market to cut corners the beams would be ready now. it's been almost a year of
development in sourcing and tooling a beam for OG needle roller bearings alone. I know word-of-mouth is important and although the Australian VW scene
is big, the community is small and people talk. I'm not doing anyone any favours cutting corners.
At this stage it's shout-out to let the community know new Australian made bus beams are only around the corner so I'll keep posted and they'll be
ready very soon.
Thanks again guys
If there's any more questions please ask.
Sounds great dude! I'll be lookin out for a beam. My son has just asked to do a Kombi as his first car. Something like that lowlight duelcab would be spot on! Love it
No problem wiseolddub! Look forward to it.
i hope we are seeing you guys at Valla!!
Good to see someone willing to make the effort and take the step to offer something that is wanted.
Thanks for the support vassy66T1
This awesome. All the best guys
Thanks bens1964vw!
Cool. Any plans to do dropped spindles?
Hi T-34, not at this stage. Ard you looking for bus or bug?
Yes I run transporterhaus flipped spindles on mine. They're a top quality product and worth every cent. No plans on doing these at this stage I'm sorry T-34.
"understated" does bay 2.5 inch zero offset , great quality or get some wagenswest ones , or convert to split beam , flipped spindles and csp disc conversion to keep wide 5 alot more clearance when slammed as beam tubes are closer together , good luck with beams ..top idea
Or a beam raise
Gives you 2inches
Thanks Klaus!
if you can find someone to narrow a type 3 beam good luck ,they have 2 splined torsion bars and the upper bar is a sway bar of sorts , , there where welded drop spindles avail once and bert3 made billet drop spindles awhile ago and i think he was going to make some more , but he is in the us or eu?
