WTD: 12 volt ALTERNATOR
terry1 - September 7th, 2012 at 11:10 PM
wanted 12 volt altenator to convert 40 hp bug to 12 volts from 6::
h - September 8th, 2012 at 06:59 AM
prolly best to get a new one mate
as well as a stand n prolly fuel pump too
68AutoBug - September 8th, 2012 at 10:38 AM
Originally
posted by terry1
may be difficult to find a used one these days
lots of New ones about... cheap [and probably chinese]
or New Bosch alternators..
and as noted You will probably need a new alternator type of fuel pump as the original fuel pump won't fit with an alternator
as the alternator is too wide...
where are You located???
it may cost too much to send an alternator across Australia??
68AutoBug - September 8th, 2012 at 02:19 PM
Hi again
2nd Hand 12 volt Generators are much more available and much cheaper...
also very heavy to freight..
You would then need to replace all light globes - everything electrical ..
otherwise they will BLOW first time they are connected to the 12 volt battery
COIL- CARBY AUTO CHOKE- ALL BULBS- BLINKER UNIT-
WIPER can be used with a resistor [coil resistor off old fords etc will do] starter will work on 12 volts.
