looking for 16" vw look a like rims etc merc/vw with right off set(37) to go on my 74 bay .5x112 stud pattern already have 205x65x16 tyres plus white
wall inserts .You may have other suggestions.Have tried mercedes vito.
send pm or ph john 0414954453 thanks
Try Mercedes Vito steelies too, just make sure you check the stud pattern as I think some were not 5x112.
Thanks mercedes vito right stud pattern 5x112 but wrong off set.Offset is to big need 10 mm spacers which you lose your thread for nuts.
seen peeps running these in their busses.
From a Ford Territory.
Call Jono if interested. 0418 444 356
On my old bay i ran ford falcon 16 inch chasers that came from Ba series 2 up to current fg, looked sweet when lowered, heaps of tyre places have them and from memory got a set for $15, even made time to try out differnt tyre combos to get the right look for me.
thanks split will have a look for 16"ford falcon ba series
If I'm not mistaken (it _has_ happened before) both the Territory and Falcon wheels are 5 X 114.3; they can be "made" to fit with some ghetto
engineeering but it's not something I would do, especially as there is a wide range of 5 X 112s with a variety of offsets available from Mercedes,
Audi, BMW etc.
I have seen wheels come off moving cars in South Africa, Fiji and Brazil so far - in fact I use it as one of the measures of state of development,
together with the use of DDT to control mosquitos, but that's another topic.
hth
Yep, I'm with Peter above.
Ford have a 5x114.3 pattern (same as Nissan and other Japjap cars).
I don't recommend doing ghetto mods, best to either change brakes or just get a different wheel.
Whilst Ford is only a 2.3mm difference, thats enough to not seat the wheel properly and combine that with the fact Kombis use a ball seat wheel nuts and Ford wheels have a taper seat wheel nuts there's Darwin award written all over it.
Nothing to do with fun police it is bad engineering practice that will load the studs in a way that they are not disigned to handle. just ask any automotive engineer if he would put his name to it.
Hi,
See pics, a friend took these of his Merc and wants $400 for them, I think there is only 3 caps but can find out.
Cheers,
David
0434 58 22 64
Cheers,
