-Does Hella or any other company make replacement tail lights that are the same as original Country Buggy tail lights? If so does anyone have a
source on where to get them or any part number for them?
-My CB has its tail lights but the rubber seals are cracking and weathered
-I see Hella also makes a license plate light housing but I am not sure if they are the same as the original CB housings. The replacement Hella ones I
am referring to are part numbers 2557 and 2550.
My license plate light housing looks a lot like the 2557.
If anyone knows where I could purchase or if anyone has the following items to sell I am interested in buying them:
-Rubber seals for tail lights or full tail light assemblies
-Rubber seal for a license plate light housing or complete license plate housing
-Pair of Hella 2100 front blinker assemblies
Thanks!
This is the Hella 2550 license plate light housing. I dont believe this one is correct.
This one looks more like the one I have on my CB. This is the Hella 2557
The dimension photo wouldn't download properly but the dimensions are 108x44x40
Hella 2100 turn signal housing
The 2557 is correct, just have to paint the silver bit black from the outside.2100 are still available both hella & aftermarket (crap quality).
regards Paul.
Good to know that the 2557 is a correct replica.
It will be Hella for me on the front signals for sure. Only a couple bucks more than the cheaper ones. I was able to source both the 2557 plate
light and the Hella 2100 turn indicators.
Thanks for the feedback guys. I had no idea the Morris used one so similar.
I also sourced some Narva Rear Stop / Tail, Direction Indicator Lamps part number (Red / Amber)- Blister Pack
The part number is :
86010BL
Looks and size to be very close to if not exact to the OG Hella Tail Lights except for a chrome instead of black outter trim.
Hopefully they are the same size so I can use my Original Hella lenses in them.
Has anyone on here used these lights on their CB?
Yep I have the Narva Tail lights on our CB. The bolt up to the original holes in the bodywork. And I got the front indicators from Supercheap with the LED's. They look original, but pretty bright when they operate.
Great news and thanks for the information.
The mini lights were Lucas .The Holden 1 tonner come out with the same black Hella nu. plate light.
regards Paul
