My '67 project will be lowered either one outer spline or one inner ( haven't decided yet ) but it will no longer always have the axle tubes sloping
down so I am worried that the bearings may dry out. What do people think of sealed bearings or what life should I expect if my camber is always zero
or negative?
Thanks, Dan
unless it is super super low you shouldn't have too many issues. Bearings must have lubrication and oil/grease starvation can lead to almost instant failure. Even with a bit of negative camber oil will work its way down, or up, to the bearings as you go round corners etc. If you are going really low or will do lots of long highway miles without much cornering then maybe sealed bearings would be better but doubt a couple of notches will be that servere. otherwise do the F1 weave left to right and that'll get the oil out to the wheels.....
Thanks Lou!
I have also heard people use sealed bearings but pop the inner seal out. This ensures oil gets to the bearing but the remaining outer seal ensures oil
NEVER leaks onto the brakes if the O rings etc fail. .........I think thats a pretty GOOD idea!
Just pack your standard bearings with high temperature wheel bearing grease that is compatable with your gear box oil, works in the front wheel bearings.
If you leave one seal in how do you lubricate the original seal. if the grease is compatable with the oil it does not matter, just gives you some more protection.
You would need to put a small amount of oil between the lips of the seal so they are lubricated..
I do that with all oil or grease seals otherwise they are dry and wear down fast until the oil or grease can get thru the inner lip..
and the grease [lithium based MOLY grease] won't hurt anything
Thanks for all the advice guys
OK, so I have just bought a pair of NSK sealed bearings 6306DDUCM
(Japanese quality so they should last a while ). I will pop the inner seal off, pack some more grease in and see how they hold up. Watch this
space!
Cheers, Dan
sorry been missing this thread.
Lee, you shouldn't mix up lithium grease with moly grease. Lithium grease is def the way to go as it is formulated for "rolling " bearings. Use
an EP2 Lithium grease. so called "moly" grease is a molybdenum disulphide grease and it actually is not suitable for rolling type bearing such as
ball and roller bearings. It contains mircoscopic Mo2S particles which are actually harder than the bearing surfaces and if larger than the film of
lubricant seperating the balls or rollers from the raceways can cause wear. This type of grease works well in sliding type bearings, CV joints,
bushes, etc.
the C3 is a bearing with slightly higher internal clearance. Not so much more precision but actually more internal clearance so that when it get s
hot is does not preload itself too much. It is commonly used in alternators and such which tend to run hot due to their environment.
hope this helps.
Louie IS the Bearing Genius
Good info. there, lou0060. Not many people - even those using bearings every day - know what those 'dots' or 'diamonds' mean.
Furnace or oven circulating fans run really big clearances when the shaft temp. is much higher than the casing. Some car manufacturers fit 2 or 3 dot
bearings to allow for slight misalignment or flex in axles, and not so much for temp. differences.
It's interesting how they make the 'clearance' bearings.....the grinding is the same as standard bearings, but the temperature is varied for each
different clearance.
