Any ideas. Whats the best stock (or close to it) shockie for a 68? Its an IRS rear so something compatible with that. I currently have these silly
looking coilovers which I want to get rid of - don't really have a need for coilovers on a stock Beetle.
Any to go for (or any that should be avoided?)
Bilstein, Koni.........
Boge. 27-221-9.
Original fitment, european manufactured. usually reasonably priced and readily available.
KYB gr2's, excellent standard gas replacement shock, available from the US for about $250 a complete set to suit your car delivered, part # for your
car, 343143 front, 343144 rear.
http://www.ebay.com.au/itm/KYB-GR-2-STRUTS-VOLKSWAGEN-BEETLE-TYPE-1-1967-1977...
http://www.eshocks.com/bil_veh.asp?Model_Index=77Q11&Manf=All&SubChar=Q
Any problems posting gas shocks? Can post normal ones but any compressed gas can't be posted which ups the cost to buy them.
No issues, have purchased several sets of gasajusts from ther states, last set was two months ago.
oil shocks , got ours from autopro.
Monroe GT Gas, they're Australian made and they're cheap! I've never had an issue with mine.
Boge or Bugpack for oil only and then KYB, Monroe, Bilstein, Spax, Koni and so on for gas/oil shox.
Be warned that the gas shock can give a firmer ride than an oil shock just from the nature of it's design so something to bear in mind.
all because of the increased damping which is required when you modify your suspension.
