I have an Australian RHD 56 oval. Can some one please post a pic and description of what the original horn should be on this car?
Much appreciated.
Paul
It should have screw on terminals not push on type
Looks similar to the 60s type horn
could be either Bosch or Hella
Do you need a picture
I suppose that's what I need to know. Is it Bosch or Hella? A pic would be great vw54. Thank you.
On my 57 it's a Bosch. Original to the car. Will try to post a pic.
heavy as held on by 14 mm nut
need one??
Yes all the nuts n bolts on an Oval are 14 mm not 13mm like 62 onwards
This is the one on my '56
NOPE not letting us see yr pics
now?
looks the same as mine
Thank you VW54 and old Dubber. If you look closely at VW54's pics you will notice "Made in Australia." So I would say definitely Bosch- Screw Terminal- 14mm nuts and Made in Australia. What other Bosch items on a 56 should be made in Australia?
My 56 has the same as the ones posted above!
