Wider track? front and rear?
splat - October 30th, 2014 at 03:05 PM
Was told i could widen the front track of my 67 bug by using 68 spindles? true? also how about the rear?
Any help!
Joel - October 30th, 2014 at 07:23 PM
No not true, 67 is link pin, 68 is ball joint so the spindles won't swap but even if they did it wouldnt widen the track.
Swapping to 12 volt long axles will widen the rear about an jnch per side but a lot of work for not much gain.
splat - October 31st, 2014 at 02:56 PM
Cheers Joel.
Phil74Camper - November 1st, 2014 at 10:39 AM
The easiest way to widen your track is to fit wider wheels and tyres front and back.
These Porsche 356-style chrome wide-five wheels are 5.5 x 15 and bolt straight on. They take 185R15 tyres without rubbing on the guards. They also
take the stock VW hubcaps for the classic resto-custom look. Good VW shops like Micks and VVDS stock them, or they're easily available online.
thebugnut - November 5th, 2014 at 10:25 AM
Joel, VW started putting ball joint beams in Bugs in 1966. True it won't widen the track any but '67 was NOT a link pin beam.
1303Steve - November 5th, 2014 at 10:32 AM
In Australia we only king & links until 1968 and 6 volt as well
Joel - November 5th, 2014 at 01:01 PM
Originally
posted by thebugnut
As Steve said above it was in Australia, we didnt get balljoint till fatchicks started in 68.
Our 60-67 beetles here were virtually unchanged, just a few minor things like bigger 1300 engine for 66 and 67.
Phil74Camper - November 6th, 2014 at 08:29 AM
Originally
posted by thebugnut
As Steve and Joel have said, Aussie '67s WERE link pin. Your US Beetles were built in Germany, but ours were not. They were built in Melbourne, with
up to 95% Australian content. We didn't get most of the German improvements from '65 to '68. A bit like other unique Beetle models from South
Africa or Brazil.
The differemces between Euro/US Beetles, and their Aussie equivalents, is documented here:
http://www.clubvw.org.au/austvw001
