I just fitted a new Empi indicator switch to my 72 super beetle, everything works fine apart from they wont auto cancel when you turn the wheel. You
can hear it click but its like the mechanism in the switch isn't strong enough to return the switch back, the arm is a bit stiff but not real bad.
Anyone else had this problem with Empi indicator switches? If its a Empi switch problem, I will send it back and get my $89 back.
EMPI is the word
check and see if the cancel section is in the correct position on the steering wheel
YEP steer clear of all the EMPI products
