Starter problem
ultrasuede - May 22nd, 2017 at 11:21 AM
Iv'e been driving this around for awhile now, but I want to nip it in the bud.
The starter solenoid clicks, the motor spins, it engages for a second, then lets go and spins. The solenoid remains engaged until I switch off ignition.
The flywheel is fine, no worn or missing teeth.
Any ideas?
southspark - May 22nd, 2017 at 01:20 PM
Its your starter drive.
Regards Paul
ultrasuede - June 4th, 2017 at 06:16 PM
Is this what you mean?
grumble - June 5th, 2017 at 05:33 PM
Yes the overrunning clutch in the bendix drive or wear in the solenoid mechanism.
southspark - June 5th, 2017 at 06:59 PM
The teeth on the drive should be 90 degree not angled ,also check your ring gear right around, should be the same on all the teeth.
Regards Paul
