Just a quick question. How do i go about slowing down a beetle 6V wiper motor down on a 12v system. My Car has 2 big old resistor, but have no idea
how big they are or where they come from. My brother is now going thru the same dramas, cant find the resistors, or anything to suit.
Anyone know of an easy fix? or a better way?
I've been told i can buy an adjustable resistence meter guage thingy from Jaycar.
Or cant he 12v and 6v motors just be swappped over?
any help would be greatly appreciated on a topic that seemed like such a no brainer, lol
Boozo
12 volt armatures are available for the 6 volt motors.
http://www.cip1.ca/ProductDetails.asp?ProductCode=VWC%2D113%2D955%2D811%2DB
I think the 6v and 12v motors rotate in different directions or some thing making them non-interchangable.
You should be able to find the resistor at one of the specialty vw places
Go to somewhere like Repco and get a Ballast Resistor(the big white ones) like the ones that are used for 8V coils.....you will need to run two of these resistors in series. They are about $6 each
Or get a mitsubishi colt headlight dimmer control.
Wire it up and you can dial the speed from fast to slow depending on how much the rain comes down !!
Worked a treat on my 58 beetle
Thanxs for the help guys, i was wondering where i found those resistors, and now i know, thanks again
im worried about a dimmer switch getting too hot while slowing the wipers down so the ballast resistors seem the way to go
