hey hey all,
I have just replaced the speedometer cable in my 74' L-bug, because the old one had snapped, and ive noticed its been making this whirring sound, and
the needle in the speedometer has been pointing to the right speed but its wavering up and down around the point.
Any ideas whats wrong?
Thanks heaps all.
speedo is probably starting to sieze up
I've had cables that are close to snapping give that sort of effect too.... did you replace with a new one, or just a used one from somewhere ???
It was brand new, German made as well
Joel, what do you mean?
theres alot of rotating parts inside the speedo that wear out or get tight after 35+ years
ive seen speedos that have had the inner workings seize up and jam then next thing the cables snap
tell tale sign is the moaning noise they make before hand
a good lubrication can usually fix the problem but to do it properly involves taking the face off the speedo which isnt a big job, just fiddly
Burgo i had the same problem awhile ago and just removed the speedo head and lightly oiled it - like Joel said.
Dave
thanks all, i ended up removing it and the way i had put it in the last time had put a big kink in it, Now i just rethreaded it so it hasnt got that
and oiled it, and its fine now
Thanks for the advice all.
