what year was the last of the small front window
what was the last year for front end with the shocks lioke the type 1
You've posted this under 'Bugs', so I assume you are talking about a Beetle.
The VW windscreen changed several times. The small windscreen fitted to oval-window Beetles was enlarged in 1958 when the back window was made bigger
too. This bigger windscreen was used on all subsequent 6-volt Beetles up to early 1968.
In 1968 the windscreen was made bigger again, with a very slight curve. This windscreen was used on all subsequent torsion-bar Beetles up to their end
in 1976.
The 1971-72 Superbug S (1302 to Europe buyers) used the same windscreen as the 1968+ torsion bar Beetle.
The 1973-75 Superbug L used a new, much bigger windscreen - taller, wider and very curved.
Shocks - are you talking about beam front ends, rather than Superbug-style struts? Beam front ends were used exclusively to 1971. From 1971-75 you
could buy the 1600 strut Superbug, or the 1300 beam Beetle. In 1976 the Superbug was discontinued, and for this last year the Beetle had a beam front
end again.
All Beetles are 'Type 1's whether or not they are torsion beam or Superbug strut. Cabrios, Karmann Ghias, Country Buggies and 181s are all Type 1s
as well as they are based on the Beetle.
your thinking of brazillian or mexi bugs Lee,
the last of the Emden Germany bugs looked like ordinary 70s bugs,
they were 1200s so had the no vent decklid and low back seats but everything else like bumpers lights etc and big windows were all standard euro
spec
heres one of the of 300 from the 1978 last edition series
thanks guys excellent
