what is the thing above the coil in this photo of the engine ???? (the long cylindical thing? ) Any ideas ???
This car is listed on Ebay
http://cgi.ebay.com.au/1958-VW-Volkswagen-Beetle-Original_W0QQitemZ2705313064...
Cheers Todd
I agree with Lee that it's one of those petrol catalyst
that claimed to improve power and efficiency
reduce emission
something like this: http://fitch-fleet.com/
But in fact do nothing.
If they had any effect at all, manufacturers would fit them as standard. But they don't - so they don't.
You might as well add snake oil to the crankcase too.
isnt that one of those jobbies that takes the place of the lead in the fuel, lubricates the cylinders by adding something to the fuel as the fuel passes through it?
glad to see i'm not the only one in the dark . I figured it was probably one of those fuel saver thingys .... ...
Todd
thanks guys
Whats ur current drive mat???
Drive/work truck is a '91 wbxr panel. Building street/race offroader 2.9 type IV ![]()
sweet ... look fwd to seein it ....
Some are just a magnet. Waste of money. + filter in a bad spot.
Popular Mechanics have tested all of these supposed fuel saver gismos, a number of times, over the years. NONE of them work. Many of them reduce
performance.
Magnets don't work as petrol is not a dipolar molecule and hence does nothing in a magnetic field. The dissolving in fuel thing doesn't work either,
as tin is not soluable in petrol. Even if it was, you would have to replace the cannister at every fuel refill - with the Nulon lead substitute, for
example, you have to add the little bottle to every new tank of fuel. Yet they claim these cannisters last the life of the car - in which case nothing
is being added to the fuel. And Volkswagens don't need lead substitutes anyway as they already have hardened valve seats.
Bad science, bad engineering and a complete waste of $$$.
