Hi All
Just checking to see if anyone has fitted the new Mexico TP 1600 engines that Classic and others sell, how well do they go?
Love to here of your experience with these motors
OK if kept stock, they have a cast crankshaft, so definately on hiperformance or they wear out fast....from what I've heard, as I've never owned one.
yep.
yep
original VW cranks are forged
As long as it has not been re-ground 4 times than it will be a good choice
That said - there are a lot of the cast cranks out there, both aftermarket and VW
If you just want a new motor - they "apparently" are not too bad
Remember - thay are only a long block
So you still need a donor for all the other stuff.
If you donor is in has a good case and crank - i would be more inclined to rebuild
Ours has only done about 4k on it in the last 2 years so it is still a bit tight. It starts well and idles nicely but it is only a 1600 so not for
spirited driving. Having said that, it still pulls nicely and is very reliable.
Yogie
