I went to see a 1975 Super Beetle today. While looking under the rear bench seat for rust, I found that it had a vacuum assisted servo for the brake
system. Has anyone seen this before? It was in the space under seat on the other side of the battery. There was a vacuum hose from the engine bay to
the servo.
The Beetle was fine otherwise.
Michael
Hi Lee
I didn't take a photo. The car was listed in carsales.com.au.
It is the white 1974 VW 1303 for $6999. No photos of the servo in the ad either.
The car had a very complete engine. All vacuum hoses present, carbon canister, thermostatic bellow.
The servo under the seat put me off though. The guy bought it off a dealer and wasn't using it much.
Michael
sounds fine to me. ive got one on my car but its not fitted there.
If it's under the rear seat it's not going to be a brake booster, they are a part of the master cylinder which is under the fuel tank.
Probably something silly like a cruise control servo or similar
it probably a vh 40 or 44 remote booster, i wonder if it is on the whole brake circuit, being a dual circuit system you would need two to boost both back and front
There couldn't possibly be anyone out there stupid enough to boost only the rear brakes
As i said there might be another booster for the front or it could have a single circuit master cylinder
That does not stop people from doing stupid things like that, it's also illegal to narrow a beam and there's plenty of those around.
