Hey guys,
As I've stated before, i SUCK at suspension, so rather than dick around, I'd ask some experts!
Eventually I want to lower my standard 1969 1500 on some Fuch's, but in order to get the ride height I want I figured a narrowed beam is the way to
go
Having a look at Volks.com.au, I didn't know which beam is right for my current set up...
http://www.vollks.com.au/index.php?main_page=index&cPath=188_200
Could someone explain which one is the right one, and more importantly, why? If anyone has a good website/link of how beetle suspensions work could
they also shoot it through?
Cheers guys,
Ollie
PS I really only want to go 2"
I narrowed my own, theres a lot more work doing a balljoint beam than there is doing a link pin beam,but if you can do it yourself go for it saves a
lot of $$$ and i think the ones you buy are for left hand drives so you still got to play around with them???
cheers shane.
Just remember all these beams are for left hand drive and need the brackets welded to the right side. I bought one from vollks didnt have a problem with it.
Paul so yours was RHD when you got it or adam changed it,if they sell them ready to go i would grab one from them![]()
cheers shane.
Adam changed it over i'd suggest you call Adam get him to change it over but if i recall they used the brackets off my beam and welded them onto the new one
