evening all
does anyone know if a early 60's interior will fit into a 56 oval beatle, particulary rear seat?
I have a 56 oval without the interior but have access to seats and door pannels from a early 60 (62 I think) bigger window beatle and am hoping they
will fit.
I can go down the trial and error path but thought I would post the question in case someone knew one way or the other before I go to the hassle of
getting the bits together.
Yep should fit,im running early 60s standard seats in my 56,the top peice of the back seat has more rounded ends and not as wide as later ones,if you get my drift ???
thanks - will give it a try
I can supply you with correct seats , interior etc if you get stuck.
