Hey guys,
I emailed an american company regarding the wiring loom for my 63 beetle and apparently i can use a LHD wiring loom on my RHD beetle. I'm not really
100% sold on the idea and was after your opinions.
Iy won't fit without modification, something to do with wires on the LH side and the steering wheel on the right.
What model car and what's wrong with the wiring? I always try and repair/restore the original.
The wiring i originally had was repaired as the idiots who owned it before me used an extension cord or something. I got a quote from an auto
electrician and he said it would cost close to 2 grand to re wire the entire car. The wiring i have at the moment ran through the roof of the car.
I'm thinking JK for the wiring loom but it is still a little pricey and can't justify spending over 500 on it. Anyway thanks for your comments guys
Peter
its just a time consuming fiddly job wiring a car...
what side of the roof did the wiring go thru?
the left hand side. The wiring is really crappy and it has so many earths in places where it is not needed.
Hi Peter
Earthing is what breaks down in old cars first...
I earthed every light fitting etc when I rewired My beetle.
Means My beetles lights etc all work perfectly due to a perfect electrical system
I wired up My Son's 56 beetle using the original wiring and had to earth everything to get them to work properly..
My Son didn't want any extra holes drilled etc so made My job very difficult... and He had a lot of problems early on until I earthed everything..
without drilling any extra holes... lol
so using 5 wire trailer cable You can run it to each tail light and earth each light... and use plastic screw in connector strips [Narva Hella] but
use the VW wiring system..
as I wired everything seperate but now I have about 50+ wires behind the dash... lol
wrap a piece of masking tape near the end of each wire with a label or number etc...
an earth connection thru a rusty screw or bolt and contaminated copper wire connection isn't good..
just do one or two wires at a time...
LEE in Scone NSW
i'm going to give it a shot, thanks for the advice again
Grab a used harness from a wreck, fit and do any repairs reguired. I'd do a stock beetle rewire for 1/2 what you've been quoted.
Theres new RHD wiring looms on EBAY. CAme across them the other day whilst I was looking for LHD looms. Brand new in the correct colors. Roughly around $200 to $260
I can't find them at this moment but I have seen them as recently as 2 months ago. Keep checking and I'm sure youll see it soon.
