Hey, I noticed an oil leak a few weeks ago but only recently was able to take a good gander at it. Its coming from where the bottom part of the black
cylinder (right of the picture) meets the top part via clips. There was no o-ring and the pipe connected to the top on the left of the image is
cracked slightly - could these cause it?
Any help is super greatly appreciated
( keep in mind I'm a layman so
don't get too technical with me)
It is your air filter / oil breather set up
I am guessing it is an oil bath type and should have an oil ring.
May take time finding.
If you don't get right answer here try on Kombi Klub
I think you're right with the 'oil bath setup'. I took off the bottom part and there was a fair amount of oil in there... Like a bath.
Thanks for that, I'm having trouble finding an o ring suitable for the oil bath though? Can't seem to find it online. Is there a link you could
perhaps send me for the o ring? Seems to be invisible to my google searches.
Thanks for the response/s so far!
There is no rubber "O ring" between the bottom and top of the oil bath air cleaner, just metal formed to a O shape on the top piece, that mates with
the bottom canister.
This metal to metal seal must be in good condition - check for dints or the edges folded in.
As previously stated, only fill to red line inside canister
Hey, thanks for the advicr, everything you're saying looks to be true, it fits well enough so I'm just gonna fill it up and see how it goes, maybe I
just went over a speed bump a little fast and spilled some oil that way.
One final question, which oil should I use to fill it up? Just the recommended motor oil (SAE30)? or is there a particular oil?
Any (clean) oil can be used. Can use left-overs etc. Some of the engine oils are very thick, so we changed to using left-over ATF instead, which are
quite thin (roughly like 5W-20 or 10W-30) and maybe allows easier engine breathing... Also can tell it apart from engine oil if it seeps out...!
Drain and wipe out the lower part of the bath first. The top part containing metal gauze can be soaked in kero if it is dirty (NB. Keeping It
Upright!); then allow that to drain off completely before re-assembling (can leave on rags or paper to dry out).
Thanks a lot! Appreciate all the help with this, sorry if it seems trivial but it looks to be pretty hard to find info about it else where.
