Im looking at buying a 89 T3 auto, and am wondering if there are any problems that i should be looking for? and if the auto T3 is any good compared to
the manual T3?
I would really appreciate some help
The auto is stronger than the manual. Very reliable gearbox.
Are there any problems that commonly occur in them?
Thanks AA003
Check for any water leaks /cooling system. Around the head to block rubber seal and the top head stud sealing nuts. ANY leaking can be big $$$
And , same, ie. auto is strong, should behave 'normally', change smoothly etc.
I have owned several T3 autos and enjoy them.
Great to drive. Heavier on petrol, but worth it in my opinion
Main trouble I have had with the auto is being "sluggish" to change into 3rd when cold.
This was fixed with a screen clean and new fluid
I have heard the T3 auto has a common problem where the inner seal leaks into the diff causing eventual failure.
Otherwise they are just thirstier on fuel and according to a mate that's had both, the manual pulls loads better on hills.
in 15 years i have never had that leak problem - but yes they are thirstier, but damn, it is worth it
