T3 wheels
maharg - September 6th, 2016 at 08:53 AM
H.
Ive got a T3 dc and its running with Audi A4 rims, but there are spacers installed in order for them to fit.
Ive just purchased another T3 dc for my apprentice and wanting to put some cheap mags on it, preferably with out running spacers or do any modifications.
Anyone know what wheels bolt straight on preferably keeping them 15".
rocknrob - September 6th, 2016 at 10:05 AM
mercedes has plenty of sizes that fit...its all about the ET or offset...less than 40mm is good
zoofish - September 6th, 2016 at 11:27 AM
A set for sale in the Parts section:
http://forums.aussieveedubbers.com/viewtopic.php?tid=111521
DasAuto77 - September 7th, 2016 at 10:17 AM
Audi A4 rims have offsets about 43. I trial fitted a4 16X7.5 wheels to my t2, 225 tyre didn't clear trailing arm. However, Audi A5 rims have et about 30 and are probably better bet. Now running 15X7 titan performance et 25 but these are now only available in 16 inch. These do fit straight on to a T3 once longer studs/bolts acquired. If you don't want to go longer studs, then merc steel wheels.
roverv8bay - December 1st, 2016 at 07:21 PM
Good evening all. Rockenrob what would possess you to file the holes out to fit wheels that the nuts wont seat in properly for the sake of cheap rims the rounded seat of the kombi nut compared to the flatter falcon is a safety issue. Hoe often do you check the nuts for tightness.
