Gdy guys.
Im having a bit of a problem.
LAst night I completely unhooked and unbolted the ignition switch.
Then It came to sliding it off the steering pole. I moved it up a bit but it now doesn't want to go any further. And now my the black tubing around
my steering column keeps pulling out when I pull to hard on the ignition case.
Here are some pics. Does anone have any tips for getting it off?
If the steering lock is not engaged, it should come off.
It's supported in the housing by a large rubber bush. You may have to take out the top circlip and washer to make it easier. Clean the top of the
column and use some lube and the housing should twist off the column.
I think you have to slide it off from the bottom,thats how i did my 69,cheers shane.
Okay Thanks guys!
Old Dubber- Your a legend. I'll have a crack at it tomorrow.
VW Mad- Do you mean pull the black steering shaft housing off the shaft and then pull the ignition off the bottom?
Yep i think thats how i done mine,not 100% sure but give it a go if you get stuck cheers shane.
did you undo the grub screw
NO! Where is the grub screw
to get the electrical part of the switch out there is a little plain blade screwdriver grub screw ,as i had mine out of my 73 when i first got it
,till i got a key cut![]()
No I just want to take the whole thing out. I have done it before but I cant think what I did to make it come straight off.
All Fitted! And I have done half the lectrical. I'll show pics soon.
Mmm
